Experts only: need Cross for Kubota Hydraulic Filters
   / Experts only: need Cross for Kubota Hydraulic Filters
Yep the Fram PH8A fits everything:D I was yanking your chain.....made my point about internet experts though:cool:
good yank.
nearly got this worked out for myself. Took the old filter, confirmed thread, used micrometer to measure gasket ID/Od, and metal OD. and got the R values. getting there.
   / Experts only: need Cross for Kubota Hydraulic Filters #12
Hopefully when you finally get there, there will be no need to come back. You have teebagged a few good people here.
Dave
   / Experts only: need Cross for Kubota Hydraulic Filters #13
Dave
Well said Dave,
50 acres, carbon negative sustainable farm , he's all carboned out. we should go easy on him.
   / Experts only: need Cross for Kubota Hydraulic Filters #14
Expert- Someone who knows more and more about less and less, until they know absolutely everything about nothing.
   / Experts only: need Cross for Kubota Hydraulic Filters #15
Go to NAPA. They have cross referenced for both my Kubota B8200, and my 1941 Farmall "A".
Tisco cross references both of my tractors too.
Otherwise, got to Kubota direct. There's even a couple dealers here on TBN. Carver has been great to work with in the past.
And, ask nicer...
Please do not send me to a web site, unless you went there first and confirmed that it provides an answer.
Here are the 3 Kubota Hydraulic filters, from the parts manual:
38240-3771-0
38430-3771-0
30400-3711-0
thanks in advance for your consideration!
   / Experts only: need Cross for Kubota Hydraulic Filters #16
While I would probably feel ok using a WIX or other filter for the hydraulic circuit filter I think I would only use Kubota for the charge pump Hydro filter as even the Kubota ones have blown out. You need to match media size and flow quanity, thread size and pitch, diameter of base and the most important is the drainback valve and pressure relief valve settings.
David Kb7uns
   / Experts only: need Cross for Kubota Hydraulic Filters #17
http://indianpaintbrush.com
50 acres, carbon negative sustainable farm,
in process. Also, trying to break even in
5 years or less!
Just wondering, doesn't a Kubota Tractor create more carbon (carbon monoxide)? Wouldn't a horse and plow be more carbon negative? But, only respond if you're an Expert.
Also I believe the web link "http://indianpaintbrush.com" is not functioning, that is, it's Not Sustainable. ;)
   / Experts only: need Cross for Kubota Hydraulic Filters #19
I can't get the link "http://indianpaintbrush.com" to work either, was kinda curious about it.;)
   / Experts only: need Cross for Kubota Hydraulic Filters #20
Dave
Well said indeed!
CAT 350E2 Haul Truck (A55272)
CAT 350E2 Haul...
UNKNOWN TANK MANIFOLD (A58214)
UNKNOWN TANK...
SHOP TOOLS (A58214)
SHOP TOOLS (A58214)
LOT: (2) Dewalt Electric Drills, (1) Dewalt Electric Grinder, (1) Milwaukee Grinder (A59076)
LOT: (2) Dewalt...
2018 Ford Transit 350 (A57148)
2018 Ford Transit...
2001 WELLS CARGO 8' X 32' TOY HAULER DBL AXLE TRL (A57192)
2001 WELLS CARGO...
