Extra Hyd. Valve Kit
/ Extra Hyd. Valve Kit #1
MapleLeafFarmer
Platinum Member
Canada
lots including Kubota B's, L's, cat, etc.. over many years
for the Kubota experts out there... I am looking to add a hyd. bucket grapple to my little B2620.
My B2620 came from Kubota with a front bucket and a rear frame mounted Backhoe. Plus some other goodies.
The question I have is about working the cyl. on the bucket grapple.
When I remove the Backhoe I disconnect the 2 hyd. lines from the backhoe and connect them together. The tractor then operates correctly with no backhoe attached. So with the backhoe removed, should I be able to use these lines that would normally run the backhoe when connected to run the cyl on the bucket grapple by adding a valve and hyd. lines to the front of the tractor?
thanks in advance
/ Extra Hyd. Valve Kit #2
thanks in advance
Hi Boakley,
Please check my ealier thread, it may help you
http://www.tractorbynet.com/forums/...ng/183707-extra-hydralic-bx24.html?highlight=
Good luck
/Sam
Sdlanch SDLGC80 (A60463)
Sdlanch SDLGC80...
3PT 14' 9 Shank V Ripper (A60462)
3PT 14' 9 Shank V...
2019 Harley Davidson FLHTP Electra Glide Motorcycle (A56859)
2019 Harley...
207280 (A52708)
207280 (A52708)
2007 CATERPILLAR D6N LGP HIGH TRACK CRAWLER DOZER (A62129)
2007 CATERPILLAR...
High Accuracy Meter Fuel Pump (A61166)
High Accuracy...
