EZtrak Z445
   / EZtrak Z445 #21
Yes, I work for Sloan Implement and I work on lawn mowers. I would check out to make sure that your front of the deck is 1/8" lower than the rear, that your wheels are 1/4" off the ground, and that your blades are level side to side. There is no reason why this should be happening otherwise. If you still cannot figure out the problem, I would suggest taking it to your local John Deere dealership and they will be able to solve your problem. I hope that this helps.
   / EZtrak Z445 #22
I just got a Z445 with a 54 in. deck and used it once so far. I'm very pleased. I was a little apprehensive about learning to use a ZTR mower but the learning curve wasn't bad. Still need some fine tuning. However, it cut my mowing time from 3 hours to about 1 hour 45 minutes. I have 2 other JD's, a LX 288 lawn tractor and a 870 compact tractor. All good quality products. I recommend the Z445.
   / EZtrak Z445 #23
I've been looking at the ez445, it seems like a nice compromise between a residential and a full blown commercial for a good price. JD has just increased the warranty to 4 years as well. I was thinking a used commercial mower but with the 4 year warranty I think I found my ZTR. I have just south of 4 acres, is the 54 inch with high capacity deck the way or should I go with the ez465 with the 61 inch standard deck?
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A55973)
2021 Allmand Bros...
1996 FORD F-SERIES FLATBED TRUCK (A52706)
1996 FORD F-SERIES...
Club Car Utility Cart (A55851)
Club Car Utility...
2013 Nissan Rouge SUV (A53424)
2013 Nissan Rouge...
2013 Ford F-450 Dump Truck (A55852)
2013 Ford F-450...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
