DarinRay
Platinum Member
- Joined
- Apr 7, 2000
- Messages
- 557
- Location
- West Valley, New York
- Tractor
- 2004 JD 4310 300CX 72MM, dozers, excavtors, bachoes, loader, tractors.
Hello All,
I need some help with my F215 that I have. The problem is that when you start the tractor it sounds like the pump is cavitating and the 3 pt hitch is slow and jerky. BUT if I use the tilting cylinder on the 3 pt the pump noise goes away and 3pt hitch moves quicker and no jerky on the tilting cylinder. ?????? If it was the pump it would do it all the time yes? I've siliconed the suction side of the pump thinking that the oring could be bad but no change. When i changed the oil and filter when first running the machine there is no noise or jerky motion on the 3 pt. If it was in the 3pt hitch valving wouldn't it do it all the time? Boy I am confused.
I've cleaned teh suction strainer 3 times just in case and the last 2 times there wasn't hardly anything on there. The first time it was slimy grey non metallic fillings. maybe pump material??? What do you guys think the next steps are?
Darin
Darin
