F450 with PTO???
   / F450 with PTO???
tractorboy5500 said:
Its not just vehicles, it tractors and everything else we have and own. Wonder where our major airlines have there planes built????
At the plane factory?
   / F450 with PTO??? #82
I think that my Kubota is mostly Kubota... I hope it is anyway.. that and dealership infrastructure was a major part of my decision to buy it over several other brands...
About the planes... I can honestly say I have never flown.... and never will!!!
   / F450 with PTO??? #83
NONE of them build a decent front suspension for the diesel P/U's...
My 96 F350 diesel has a leaf spring front with a solid Dana 60 axle...pretty good in my book;)
Never needed an alignment in 190,000 miles....
   / F450 with PTO??? #84
Try putting a 9ft plow on it. The leaf springs on my 94 F-350 diesel were flat when the plow was off and frowning when I lifted it...
   / F450 with PTO??? #85
every setup has its good and bad points. about 20 years ago i remember asking a family friend who was in the logging business about the reliability of the newer trucks. this was not too many years after gm switched to the independent front end and there were all sorts of horror stories about no grease fittings, plastic ball joints, etc. he ran a 3/4 ton as mainly a service/support truck for his logging business. he also plowed 50 or so accounts in the winter. he said he would never want to go back to the older style. according to him. after 30-50k miles of pounding the dirt roads the older trucks were so worn that you had all you could do to keep them in the road. he had about 150k on the newer one and it was still better handling than the old one was when new.
   / F450 with PTO??? #86
Well....YEAH..hang that much weight off any pickup front end without some adjustable assist and it's gonna sag.....can't imagine any way around that:rolleyes:
   / F450 with PTO??? #87
yeah.. that was a good one.... look under the front end of the same year truck but an F250 4x4... its "sketchy" at best..
I am actually in the process of trying to gather up all the parts to put the 1ton front end under a 96 F250.....
   / F450 with PTO??? #88
What front end do you have? The solid axle with leaf spring was about as good as it gets. Strong, simple, sturdy.
My old 89' F250 started with the Ford Twin I-beam "IFS". rode and handled nice. But the springs on those frontends sag like crazy. That was a bad overall design. It worked ok for coil springs, but leaf's just aren't made to hande all the angular stresses that that particular IFS design had.
I swapped mine to a straight axle, had the leafs rebuilt, and it was awesome!
Interestingly, the stock straight axle, turned much tighter than the stock IFS axle did. It was a long bed xtra-cab, so I appreciated that.
   / F450 with PTO??? #89
yeah.. the 1 tons had the solid front axle... the 3/4 tons had some... p.o.s. wanna-be independent front end and the Ford "auto locking" hubs... ARGH!!!
The hubs never work and the front suspension is constantly needing attention..
From everything I have heard and read, the solid axle is a basic drop-in to replace the IFS.. I've done several GM conversions years ago.. I figure this one shouldn't be that different.
   / F450 with PTO??? #90
Yes, mine was a drop in conversion. Once the springs sag, they need to be rearched or replaced though...
Mine was much nicer with the straight axle. Although the ride was not the same, it turned soooooo much tighter. And, out hunting, it 4-wheeled much better.
I geared mine from 3.55 to 4.11 too. The front axle I got had 4.11; had a shop swap the rear ring/pinion.
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2018 Ford F-150...
2008 MACK CHU613 TRI AXLE 16FT DUMP TRUCK (A58018)
2008 MACK CHU613...
2017 Chevrolet Tahoe SUV (A56859)
2017 Chevrolet...
2005 FORD F-450XL SUPER DUTY DUMP TRUCK (A52707)
2005 FORD F-450XL...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
