Factory JD TnT Cylinder Dimensions
   / Factory JD TnT Cylinder Dimensions #1
Spudland_Dave
Maine
Deere 3520 Cab, Deere F935
Been looking at adding a Hydraulic Toplink to my machine...In looking at the JD Specs from the parts site:
3.150" Bore
1.5" Rod
6" Stroke
Closed Length: 19.25"
Extended Length: 25.25"
Does anybody out there have pics of the Factory Toplink Cylinder? Do these specs match up to reality? Just want to make sure I'm on the right track before getting stuff ordered and lined up.
   / Factory JD TnT Cylinder Dimensions #2
I've got a TnT setup on my JD110. Since I was ordering a new machine, I decided it made more sense to go ahead and have the OEM setup instead of going thru the steps to "build it" myself. By the time I went thru the purchase and shipping (to Alaska) and having hoses made and buying fittings, etc.... well, it was probably a break even deal with the JD factory cost.
I like the JD system --- but the cylinders are bigger in diameter than the CCM ones and they don't have an internal checkvalve. So, they will "droop" and loose position especially whenever you turn the machine off. And they take up quite a bit of real estate at the rear of your tractor that makes hooking up implements a bit more awkward.
Long and short; I'd price out all the components for the "roll yur own" setup before I'd jump into the JD system - IMHO.
That said; I'd be happy to try and snap some pics of my setup if you're still interested. Let me know.
AKfish
I'm looking at $150.00 Total for a "Build Myself" version using a 3X6x2 cylinder. I could spec out a smaller 2" version...From the sound of it the factor 3" is kinda cumbersome?
Are the internal check valves THAT important? I was figuring for a couple hundred bucks I can bump the SCV Lever every once in a while....
   / Factory JD TnT Cylinder Dimensions #4
that woud be a huge savings off of the Deere version. Yes Please post pics when you get tit all together. Sequential assembly pics would be even better!. Parts list, release notes, recommendations, warnings, etc.:eek:
   / Factory JD TnT Cylinder Dimensions #5
I have the factory TnT on a 4520. Using a 6' back blade, the MX6 cutter or a (heavy!) Couture chipper I've never noticed any leakdown. Like you, I was expecting to have to nudge the SCV every so often, but it just hasn't been an issue.
I sometimes leave the ballast box up on the 3PH for days, and it doesn't sag in either direction that I can see.
The tractor's currently at the other end of the property, so I can't easily measure/photograph the cylinders. Sorry.
Tom.
   / Factory JD TnT Cylinder Dimensions #6
AKfish
AKfish, yes please post some pics.
   / Factory JD TnT Cylinder Dimensions #7
Hi Dave,
I've got the factory TNT on my 3720 cab. If you still need measurements let me know. I'll do it tomorrow.
   / Factory JD TnT Cylinder Dimensions #8
I am also following this thread with interest. I would like a hydraulic sidelink for my 3520. I confirmed with the dealer today that the JD TNT is not compatible with the backhoe mounting frame, so I am looking to build my own. I will just use the 3rd SCV for the sidelink as the quickest solution. I don't think I need the top link yet.
   / Factory JD TnT Cylinder Dimensions #9
jsboening said:
Hi Dave,
I was a bit too stingy to do it on the initial purchase, now i will end up doing it late one way or the other.:mad:
1999 Case International MX200 Tractor (RIDE AND DRIVE) (A50775)
1999 Case...
STAR EV 36V ELECTRIC GOLF CART WITH BATTERY CHARGER (A53424)
STAR EV 36V...
2007 Ford E-450 Super Duty 16ft Portable Office Truck (A55852)
2007 Ford E-450...
2018 JLG 10054 TELESCOPIC FORKLIFT (A51406)
2018 JLG 10054...
CATERPILLAR 140M2 MOTOR GRADER (A52706)
CATERPILLAR 140M2...
(2) 200 GALLON POLY TRACTOR TANKS (A54756)
(2) 200 GALLON...
