SPIKER
Elite Member
I ALWAYS CHECK it is actually LAW that you check you're brakes , lights and all when hooking up the trailer here. if you are caught with no lights then you get a ticket (as in fine) if you have one burnt out it is a warning ticket which doesn't cost except for the fix... Brakes should to be set (slide power indicator on most new style controllers) so that the LOADED WEIGHT (truck trailer & whatever on it) will stop by the trailer brakes only (while ideling truck in gear 2~5 mph speed with in some distance I belive it is 50 feet is what the last controller I bought said) anyhow a dragging brake controller set incorrectly will burn up your brakes pretty fast but in 5k miles? we burnt up tires that fast on one... kept locking them up rather than simple braking it would lock em or do very little, it was a cheap controller as a new one fixed the problem.
MarkM /forums/images/graemlins/shocked.gif
