Fair price for used Wall. BX42 chipper?
   / Fair price for used Wall. BX42 chipper? #1
oscar94
Any ideas? Appears to be in pretty good condition. All decals intact. Stored outside. Also is this on the small side for my Kubota L5030? I would like to get the largest chipper possible.
Thanks!
   / Fair price for used Wall. BX42 chipper? #2
I have a JD 5210. Rating is 45 pto horsepower, I believe, but it is a medium sized tractor, not a compact. Cat 2 hitch. I struggled with the 42 vs 62, finally bought a BX62 and I'm really REALLY glad I did. It is NOT too much machine for my tractor. My tractor doesn't even strain when I shove through any live branch that will fit. I could go on and on but that would be off track for your thread.
You know what they go for new, and if it is like new, I'd think a few hundred less would be reasonable. You can see pretty readily if the knives are perfect or worn, etc. These are well built and should hold up for a lifetime if properly maintained.
The BX 62 is several hundred more, but is a lot more machine and if you can afford it, you should consider it. Just look at the weights of the flywheels and the weights of the whole machines to compare.
I haven't seen anyone post regrets about purchasing their BX42, however, so if the right deal presented itself, buy it and you'll probably be happy. Use a chainsaw to cut the bigger stuff for firewood, as many have suggested. Your bigger tractor will not hurt the smaller chipper any more than a bigger chipper will hurt a tractor on the lower end of the suggested size provided by Wallenstein.
Let us know what you decide.
it is not a hydraulic feed....but the guy agreed to 900$ which seems pretty fair so i think i will get it. can always sell it if it is too small.
   / Fair price for used Wall. BX42 chipper? #5
I paid $1800 for a one-year old BX42 and don't have any regrets. Grease up the pillow block, clean out the chamber, and get to work! It sounds like you have a very good deal lined up.
   / Fair price for used Wall. BX42 chipper? #7
I'll be willing to bet that for $900.00 it will feel pretty big!
I too would snap it up right away unless it looked like it had been hit by a sizable truck. Check to see if the flywheel/cutter head spins and is not bent and hand the man your money!
Picked it up yesterday. appears to be in great shape. i would like to get a set of new blades to have a spare set around.
any suggestions of good sources?
   / Fair price for used Wall. BX42 chipper? #9
You can do that if you'd like, but for the same amount of effort as removing 4 cutters you can remove and flip 4 cutters and have the same thing. Then remove them and have them milled / sharpened if they ever need it.
I suppose you just want to spend money to make the rest of us less jealous of the great deal you got.
If the rotor spins freely, you got a heck of a deal! Just use it and be careful!
   / Fair price for used Wall. BX42 chipper? #10
2013 Chevrolet Silverado 1500 4x4 Ext. Cab Pickup Truck (A52377)
2013 Chevrolet...
Kubota RTV-X900 4x4 Utility Cart (A51691)
Kubota RTV-X900...
CATERPILLAR 308E2 CR EXCAVATOR (A50458)
CATERPILLAR 308E2...
PAIR OF 5' PIN ON FOLD UP TRAILER RAMPS (A51247)
PAIR OF 5' PIN ON...
2017 Yamaha VX1050B Deluxe Jetski (A50324)
2017 Yamaha...
2015 Ford Taurus AWD Sedan (A51694)
2015 Ford Taurus...
