Fan hits fan shroud - am I asking too much of this tractor?
   / Fan hits fan shroud - am I asking too much of this tractor? #11
Should be ample clearance between fan and shroud. Its not uncommon to swap fan belts by routing them between the fan and shroud
to get them on and off. Maybe someone can check theirs for you with the same model.
   / Fan hits fan shroud - am I asking too much of this tractor? #12
A 'kiss' solution.
If all else fails to find like a loose component or damaged part---
carefully nip or grind about 1/8 or 1/4 inch from each fan blade.
That little amount would not hinder cooling.
   / Fan hits fan shroud - am I asking too much of this tractor? #14
Broken motor mount or loose?
Most tractors don't have engine mounts. The engines are mounted directly to the transmission housing with a sub frame to support the front axle. Yes, there are exceptions but it's not the case.
   / Fan hits fan shroud - am I asking too much of this tractor? #15
Well, then how about a cracked mount? Somethings is fishy.
   / Fan hits fan shroud - am I asking too much of this tractor? #16
How about a cracked or broken shroud mount
JOHN DEERE 4100 TRACTOR (A51243)
JOHN DEERE 4100...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A51222)
2006 CHEVROLET...
2013 Ford F-150 Ext. Cab Pickup Truck (A50323)
2013 Ford F-150...
2013 GALYEAN 130BBL VAC TRAILER (A50854)
2013 GALYEAN...
SHOP MADE  MANIFOLD TRAILER (A50854)
SHOP MADE...
