Farm pro 2430 hydraulic issues
   / Farm pro 2430 hydraulic issues #1
Dsdecker7
Farm pro
How do I bleed the air from hydraulic system after replacing a couple lift cylinder lines and cartridge filter?
Have been for a few hours now. It’s jerky and slow
   / Farm pro 2430 hydraulic issues #4
OK. did you happen to clean out the strainer screen? Been a few years since I've dealt with a 30HP Jinma but IIRC there is a strainer where the hydraulic pump suction line hooks up to the reservoir.
   / Farm pro 2430 hydraulic issues #5
Where was the filter located that you changed. If on inlet or suction side of pump and not OEM they can cause pump to cavitate - starve for oil which would create symptoms you are describing. So would strainer screen clagg references.
Where is the strainer screen? I didn’t use an oem filter. Not available near me
   / Farm pro 2430 hydraulic issues #7
Did the system operate correctly before you changed the lines and filter?
Are all of the loader functions slow and jerky?
If you operate the tractor at lower RPM does the system smooth out?
If answer to the questions above is yes I would suspect new filter is the problem.
Strainer would be located inside the reservoir on most tractors transmission case. I would suggest following the inlet line back to where it connects to the transmission housing. On some tractors there a cover that you remove to access the strainer in that location.
The filter is on the left side and hooks to a hard line in fluid tank under seat
no it started getting jerky before I changed the filter. Yes all functions are jerky. No on the lower rpm. Thanks for your help
   / Farm pro 2430 hydraulic issues #9
#1, check level. If low you will be sucking air and getting that effect. I'm sure you lost a bit after doing your cylinders
is the 3 pt and fel on the same hydraulic pump
2005 STERLING DAY CAB (A56138)
2005 STERLING DAY...
2013 3400QB SUNDANCE 5TH WHEEL CAMPER (A52472)
2013 3400QB...
2013 Magnum Power MLG08 Towable Runway Closure Marker Light Tower (A55851)
2013 Magnum Power...
2019 Autocar ACX Xpeditor T/A EZ-Pack Front Loader Garbage Truck (A55852)
2019 Autocar ACX...
2000 Safari C-Series 425 40ft Panther Motorhome (A52377)
2000 Safari...
John Deere 6110M (A53317)
John Deere 6110M...
