Tractor was running great. went to start it back up after lunch and nothing happens when turning the key. Thinking it's either the switch or solenoid. Still the original 6volt +grd.
What's the best way to check for either problem? Thanks
IH Farmall 656 gas/ IH 240 Utility/ 2, Super C Farmalls/ 2, Farmall A's/ Farmall BN/McCormick-Deering OS-6/McCormick-Deering O-4/ '36 Farmall F-12/ 480 Case hoe. '65 Ford 2000 3 cyl., 4 spd. w/3 spd Aux. Trans
Looks to be ignition switch when I checked it with a test light. What baffles me is I don't have any head lights when I turn them on. Are they wired thru the ignition switch?
On some later models they were, in case you forgot to turn them off, on a separate switch.
