Farmall A - popping wheel sound mystery???
   / Farmall A - popping wheel sound mystery??? #11
When you look around the rim sheet you can see where the paint is gone from rubbing on the rim flange. That is ofter the first sign of a loose wheel. easy to find when you know what you are looking for.
   / Farmall A - popping wheel sound mystery??? #12
Man!! You guys saved me a bunch of time/effort! I had that "popping" to almost a grinding sound on a certain portion of the rotation on my rear left on my 230 Farmall.Thought I had a bad outer axel bearing. Based on what I read here, we jacked it up last nite and found one of the rim lugs to be loose. Tightened all and "Viola!" No crunch--No poping-- No errors! Keep it up guys. I was really worried that I was in for a bad time! BobG in VA
   / Farmall A - popping wheel sound mystery??? #13
Bob:
IH always used very robust bearings in final drives. You'd crack a housing before you destroyed a bearing.
I always use a little 232 threadlocker on the clamp bolts, even on my new 5030 and especially on my older Deeres.
   / Farmall A - popping wheel sound mystery??? #14
I'll second the 'durability of IH final drive setups.
When I got my 66 int cub, it was mostly in good repair, and excelent 'looking' shape.
Minor details, like a pinched wiring harness to the lights, a few dirty electrical connections on the lights, switch, and the V-REG.. easilly fixed.. also, bad ammeter.
Fluids looked maintained well.. though, the oil bath in the fan hub was empty, and the only thing int he final drive pans was a light coating of dust... no evidence that ol ever was inthere. In fact, I'm glad i didn't drive it any till my service manual arived, and I started checking things like fan hub oil, etc.
I do know why the final drives were dry though.. you have to remove the drawbar, and belly mower to get at the plugs, etc.
All is filled now, and no leaks.
I did inspec the final drives a bit before re-assembling, and there wasn't even the slightest hint of wear.. so I was realllll happy.
Soundguy
John Deere 6120E (A50323)
John Deere 6120E...
2008 Saturn VUE SUV (A50324)
2008 Saturn VUE...
2002 Ford Ranger Ext. Cab Pickup Truck (A50323)
2002 Ford Ranger...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52141)
2019 INTERNATIONAL...
2017 Yamaha VX1050B Deluxe Jetski (A50324)
2017 Yamaha...
