FARMALL M
   / FARMALL M #11
There are bushings in the front bolster also there is a thrust bearing. When you grease the ftont you need to jack up the front end to take off the pressure or the thrust bearing might not get any grease. Ive got 4 running M,s and a junked one. I like to convert them to a single tire front. makes them steer like power steering.
   / FARMALL M
i see only a upper bushing and also the thrust bearing. their apoparently is no lower bushing on the shaft. i will try that and jack up the front end before i grease it. thanks for the info
   / FARMALL M #13
Most definitely is a lower bushing. Here's an exploded view of the front bolster assy. from the Case/IH online parts store, that ought to help you out. Official Case IH Online Parts Store and Case IH Catalog for Best Parts Search and Best Parts Look Up. Case IH Parts for Case IH Tractors, Case IH Combines, Case IH Tractors, Case IH Manuals, Case IH Parts
This is a Super M, and apparently the same as an M. Case/IH doesn't seem to have the straight C's, H's And M's listed anymore, only the "Supers" since upgrading their parts site. Not sure what's up with that...
   / FARMALL M
i think i found the problem.as it wasn't anything i had messed with i overlooked it. i found the casselated nut on the end of the steering worm and shaft loose although had been cotter keyed. i tightned nut up at least a turn and a half. almost all cplay is gonr now. i appreciate everyones help on this matter thank you all again
2024 JOHN DEERE 4044M LOT NUMBER 65 (A53084)
2024 JOHN DEERE...
2025 New/Unused Wolverine 3 Point Quick Hitch (A51573)
2025 New/Unused...
Unused Delta Crash...
2018 Big Tex Tandem Equipment Trailer (A52384)
2018 Big Tex...
2025 REDELIFT CPD25-XD4 FORKLIFT (A52576)
2025 REDELIFT...
2025 New/Unused Wolverine 48in Skid Steer Trencher (A51573)
2025 New/Unused...
