Farmline 5' DX Cutter Shear bolt?
   / Farmline 5' DX Cutter Shear bolt? #11
Lowes has grade 2 the grades are marked on the head, no marks on the head would be grade two, three hash markes denotes grade 5 . Plenty of reading online about bolt grading. 23 years with one bolt that great, I have gone thru 6 in two months. Best to ya!
I use grade 2 from Lowes also in my flail mower, and it works as it should. Tested and confirmed.
Replaced mine with a grade 2 and everything has been fine. However, this weekend I used a metal detector to find the original bolt and was surprised to find that it was a grade 5. The grade 2 I replaced it with sheared after about the same time as the original after hitting some serious multi-floral rose stems and roots. I got about 15 hours out of each while mowing similar terrain and flora. Once I get the initial mow done, I figure my grade 2 will last me forever unless I let everything grow up for years and years again.
Gregg
LS G3038 H
Most people get in and go. We get on and mow.
   / Farmline 5' DX Cutter Shear bolt? #13
I use grade 5 1/2 bolt by 3 1/2 long with poly lock nut buy them a dozen at the time from local bolt and screw company usually around 7 dollars for them. I want them long enough where shank on bolt is longer than coupling with threads protruding.
   / Farmline 5' DX Cutter Shear bolt? #14
The grade 2 I replaced it with sheared after about the same time as the original after hitting some serious multi-floral rose stems and roots. I got about 15 hours out of each while mowing similar terrain and flora. Once I get the initial mow done, I figure my grade 2 will last me forever...
My grade 2 in a flair mower got tested in some very rough territory that had not been mowed in a few years. Worked fine until it got wrapped up with a bunch of heavy chicken type, wire. Then it sheared, as one would have wanted it to.
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
2005 Chevrolet Colorado 4x4 Pickup Truck (A51692)
2005 Chevrolet...
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A51573)
(1) HD 24ft Free...
NEW Wolverine Skid Steer Pallet Forks Hydro Adjustable (A53002)
NEW Wolverine Skid...
2016 Ford F-450 Crew Cab Knapheide Service Truck (A52377)
2016 Ford F-450...
2004 Sterling Acterra Cab and Chassis S/A Truck (A51692)
2004 Sterling...
