FARMTRAC 665DTC Breather Tube oil Leak
   / FARMTRAC 665DTC Breather Tube oil Leak #11
Please do keep us posted.
   / FARMTRAC 665DTC Breather Tube oil Leak #12
yoda, got the measurements today. Not that you probably need it now, but for you own sanity...
Thanks for the pic. Yea it was driving me a little crazy trying to figure out the cause. I will post the fix as soon as I hear back from the shop. Thanks again for taking the time to post it.
Okay received my 665 back from repair shop reference oil pumping from valve cover breather tube. Oil level was simply going low meaning no diesel pumping into pan. The mechanic said all checked out...engine starting and running well... No smoke..good power... breather tube not clogged etc...the oil would only start pumping out breather tube when operating temperature was reached. He said for unknown reason the crank case was holding too much pressure and he noticed that when he pulled the dip stick the oil flow from tube would stop. His fix was simply adding a rubber breather line from top of round Tac can to left of oil filter thus feeding it back up too valve cover. Worked it hard today and so far it's performing well with no leaks. Thanks for all your help.
   / FARMTRAC 665DTC Breather Tube oil Leak #15
Glad you got it working again.
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
1261 (A50490)
1261 (A50490)
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2017 Ford F-150...
Kubota L3010 (A50123)
ALTO AMERICAN LINCOLN MPV-60 RIDER SWEEPER (A51406)
ALTO AMERICAN...
2018 KENWORTH T370 T/A DUMP TRUCK (A51406)
2018 KENWORTH T370...
