Farmtrac 785- Front & Rear Mechanical Differential Lock
   / Farmtrac 785- Front & Rear Mechanical Differential Lock #1
Slacker
Durham, NC
Farmtrac 360 TLB
The Farmtrac 785 4wd states Front & Rear Mechanical Differential Lock as a feature. Can anyone explain to me how it works? Does it actually give true 4WD? Is this a common feature on tractors this size? (85hp)
   / Farmtrac 785- Front & Rear Mechanical Differential Lock #2
A differential lock makes both wheels turn at the same speed. Normally, driving wheels are designed to run at differing speeds to allow for turning. Most tractors that I am familiar with allow the operator to lock the rear differential by stepping on a pedal. This helps prevent getting stuck now and then. The articulated machines can make a front diff lock work, but I've never seen one on a conventional tractor -- I think there would be too many torn up front drive units.
   / Farmtrac 785- Front & Rear Mechanical Differential Lock #3
i thought ive read that some of the smaller AG tractors have an optional front diff lock.
it can be key for keeping the tractor pulling in a slightly wet feild in a straight line.
With the diffs locked the machine will NOT want to turn and you WILL get a lot of wheel scrub when TRYING to turn.
   / Farmtrac 785- Front & Rear Mechanical Differential Lock #5
PaulChristenson said:
You don't need them when you use JD's Greenstar for field positioning...:)
The GreenStar™ Family of Products
Am I missing something obvious? I don't see how this feature would negate the need for limited slip or locking diffs.
If I am not badly mistaken, I believe the Kubota M6800 I had for a while had diff lock pedals for both front and rear axles. I could be wrong, though.
My Farmtrac 535 has the pedal for locking the diff, but I have discovered that the differential automatically locks when one wheel starts slipping. None of the other utility tractors I have owned did that. It is very convenient.
2018 CATERPILLAR 323 EXCAVATOR (A60429)
2018 CATERPILLAR...
2019 CATERPILLAR 313FL GC EXCAVATOR (A60429)
2019 CATERPILLAR...
2022 Horizon Trailer (A55973)
2022 Horizon...
1993 Military Potable Water Tank Trailer (A59228)
1993 Military...
2343 (A60432)
2343 (A60432)
1999 Toro Reelmaster 5400-D 100in Fairway Reel Mower (A59228)
1999 Toro...
