Farmtrak 270 dtc
   / Farmtrak 270 dtc #1
tommyb2117
Farmtrak 270 dtc
Tractor stopped working overnight. Engine is not cranking and lights were not turning on. I have installed a new battery, lights are working but engine is not cranking. Have changed fuel filter and bleed air. Any suggestions on next steps would be greatly appreciated.
   / Farmtrak 270 dtc #2
Have you checked fuses? Also see if there is current getting to the starter. Not sure if your machine has safety switches, if it does then I would be checking them as well. These are some things to try and start the elimination process.
   / Farmtrak 270 dtc
I will try the fuzes next. I have looked through the manual but do not see anything on safety switches. I appreciate the recommendation
   / Farmtrak 270 dtc #4
What year is your tractor? From pictures I saw on the internet I'd be willing to bet it is new enough to have some safety switches. At least maybe a seat safety switch??
   / Farmtrak 270 dtc
Thank you both for your responses I greatly appreciate the help. I was able to find a loose connection going toward the starter. There was a fork terminal that was slipping away, I replaced it with a ring terminal to make sure it stays in place.
   / Farmtrak 270 dtc #6
Glad you got it figured out!! Thanks for letting us know what the problem was!!
2018 Caterpillar D5K2 LGP Crawler Tractor Dozer (A53421)
2018 Caterpillar...
2016 CATERPILLAR 336FL EXCAVATOR (A52705)
2016 CATERPILLAR...
2025 GIYI Stump Grinder Mini Skid Steer Attachment (A53421)
2025 GIYI Stump...
2022 JOHN DEERE 333G SKID STEER (A52705)
2022 JOHN DEERE...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2011 Ram 1500 4x4 Crew Cab Pickup Truck (A53422)
2011 Ram 1500 4x4...
