Farmtrak 270 dtc
   / Farmtrak 270 dtc #1
tommyb2117
Farmtrak 270 dtc
Tractor stopped working overnight. Engine is not cranking and lights were not turning on. I have installed a new battery, lights are working but engine is not cranking. Have changed fuel filter and bleed air. Any suggestions on next steps would be greatly appreciated.
   / Farmtrak 270 dtc #2
Have you checked fuses? Also see if there is current getting to the starter. Not sure if your machine has safety switches, if it does then I would be checking them as well. These are some things to try and start the elimination process.
   / Farmtrak 270 dtc
I will try the fuzes next. I have looked through the manual but do not see anything on safety switches. I appreciate the recommendation
   / Farmtrak 270 dtc #4
What year is your tractor? From pictures I saw on the internet I'd be willing to bet it is new enough to have some safety switches. At least maybe a seat safety switch??
   / Farmtrak 270 dtc
Thank you both for your responses I greatly appreciate the help. I was able to find a loose connection going toward the starter. There was a fork terminal that was slipping away, I replaced it with a ring terminal to make sure it stays in place.
   / Farmtrak 270 dtc #6
Glad you got it figured out!! Thanks for letting us know what the problem was!!
BUNDLE OF 96" X 40" DIAMOND PLATE SHEET METAL (A54756)
BUNDLE OF 96" X...
UNUSED FUTURE FT-13 EXCAVATOR (A54756)
UNUSED FUTURE...
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54756)
LINCOLN ELECTRIC...
2017 CAT 249D SKID STEER (A52705)
2017 CAT 249D SKID...
2003 FORD F350 XL SUPER DUTY DUMP TRUCK (A51406)
2003 FORD F350 XL...
Pair 2 - ST225/75R15 radial trailer (A55787)
Pair 2 -...
