Faulty, Low Pressure Warning Lights Illuminated
   / Faulty, Low Pressure Warning Lights Illuminated
Sounds like there is at least a bad sender then.
As for the wire, I meant checking to ground to see if the wire has the insulation chafed away and is shorting to ground.
That is the most likely reason for the low oil pressure light/buzzer to stay on after you have disconnected the wire from the oil pressure sender.
Aaron Z
Thanks for clarifying that AZ. I'll check grounding the wire this weekend. Yesterday...............it quit buzzing after a while, when I didn't reconnect it after checking operation of the pressure switch.
hugs, Brandi
Oh yeah, forgot to tell Y'all. About a month or so ago, I replaced the pressure switch. All is normal now!:D
hugs, Brandi
*Selling at Royal Auction Tampa, FL Location* Power, doesnt crank. Hrs N/A (A59228)
*Selling at Royal...
Utility Cart (A59231)
Le Roi 80-Gallon Air Compressor, 220 Volts (A59076)
Le Roi 80-Gallon...
BROCE BW260 SWEEPER (A60429)
BROCE BW260...
2004 AGCO Gleaner 3000 Corn Header (A56436)
2004 AGCO Gleaner...
2008 Toyota Camry Sedan (A59231)
2008 Toyota Camry...
