3RRL
Super Member
- Joined
- Oct 20, 2005
- Messages
- 6,931
- Tractor
- 55HP 4WD KAMA 554 and 4 x 4 Jinma 284
Oops, forgot the link...
OPTIVISORS
OPTIVISORS
3RRL said:I am a toolmaker and have several of these "Optivisors" lying around with different magnification lenses. They are the standard used in the machining trade. I took one of the lenses and glued them into my old helmet. I used dabs of silicon in 4 corners. I have not tried them into the HF helmet yet because it's at camp and I use my reading glasses under them. If you use your reading glasses AND the magnifiers you get more magnification, but you have to stick your face closer to the work to focus.
bamabadboy said:Which HF AD helmet do you guys recommend. The 91214 or the 46092. They are both $49.99, but one is solar powered.
I have HF's 91212, "1/25,000 switching speed". About a year old. It works fine.bamabadboy said:Which HF AD helmet do you guys recommend. The 91214 or the 46092. They are both $49.99, but one is solar powered.
I was smudging mine also, and that solved it. Thanks!Sandlot said:I set the angle adjustment holes (next to the tension knobs) to the last hole. No more problem with nose prints on the lens!
