FEL (boom) suddenly stopped lowering, but works in the 'up' position
   / FEL (boom) suddenly stopped lowering, but works in the 'up' position #1
LuckyPierre
TDY Mass
BX22
I have a Kubota BX22 with a LA 210 FEL. I bought the tractor used last month it's first 400 hr service which included a HST filter and fluid change. Today I was cutting and loading fireplace size logs and stacking then in the barn, no problems.
I moved the machine to use the BH, when I tried to lower the FEL boom it suddenly quit working when the joystick was pushed into the normal 'down' position. The FEL boom and bucket will raise under pressure but the only way I can get the boom to lower is to push the joystick hard left and up. I believe it's called the 'down and rollback position' (boom and bucket work at the same time) No hoses were touched, afterwards I checked the HST fluid level and it was topped off. No leaks, or blown lines so I'm a bit baffled. :confused:
Well with the help of the 'search forum' section I found a similar thread... I checked the PTO lever and found I had knocked it out of the neutral position.
Well that was painless, albeit a bit embarrassing...:laughing:
   / FEL (boom) suddenly stopped lowering, but works in the 'up' position #3
I wonder how many members would be left on TBN if only those who hadn't done/asked/posted something embarrassing could remain?:confused: Good for you for figuring your own problem out (and maybe helping the next guy with the same problem)! :applause:
1272 (A50490)
1272 (A50490)
2014 Dynapac CC4200 Tandem Vibratory Roller (A52748)
2014 Dynapac...
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A51692)
2012 Freightliner...
2025 Star EV Capella 2+2 Electric Cart (A51694)
2025 Star EV...
2012 VOLVO A40F 6X6 OFF ROAD DUMP TRUCK (A51246)
2012 VOLVO A40F...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
