FEL capacity with R4s vs turfs
   / FEL capacity with R4s vs turfs #21
My turfs are better in snow than any R4's I have been around. I am also supprised at the traction I get in dirt with my R4's. All my box blade and FEL work in dirt, my turfs have never let me down, can actually bog engine. Now when I get in mud, I wish I had R4's or R1's, but that is the only time. Philip.
I also think I get better traction in snow with r3 tires than r4 tires. My tractor is the same model as my friends but they have r4 tires. I do very little work with the loader installed on the tractor and the turfs ride MUCH better than the r4's. If I was going to use the loader all the time, get the r4 tires. If most of your work is loaderless, get turfs.
Are your tires loaded as well?
   / FEL capacity with R4s vs turfs #24
Turfs are not loaded. In snow I do use a ballas box. Old set up with R1's required chains, marked blacktop pretty bad. Philip.
   / FEL capacity with R4s vs turfs #25
My turfs are not filled. I am on level ground which helps too. I normally use the rear blade because it is quick and takes less hp than the blower. I have heard that chains work well with turfs because the chain does not fall between the tread lugs.
   / FEL capacity with R4s vs turfs #26
My rear turfs on my BX are filled. I do fine in snow, and it doesn't mark up the yard. But if the ground is really wet, I do use my JD rider sometimes to keep from compacting the soil.
2004 KENWORTH BUCKET TRUCK (A52472)
2004 KENWORTH...
2017 Ford F550 Bucket Truck - Powerstroke Diesel - Auto Trans - 4x4 - Versalift SST40 Boom (A52748)
2017 Ford F550...
2001 Volvo VNL Truck, VIN # 4V4N19JF51N250353 (A51572)
2001 Volvo VNL...
2014 Dynapac CC4200 Tandem Vibratory Roller (A52748)
2014 Dynapac...
2016 MACK CXU613 DAY CAB (A52576)
2016 MACK CXU613...
JOHN DEERE 8245R LOT NUMBER 232 (A53084)
JOHN DEERE 8245R...
