FEL CT335 Hydraulic hose ruptured
   / FEL CT335 Hydraulic hose ruptured #1
Omnipotent
Bronze Member
As is said, the hose broke, part # is 7188081, Bobcat online parts catalog says item not available. Is there a replacement part or new part #? I tried looking at Kioti but couldn't figure out the correct cross-reference.
Any help is appreciated.
JD
   / FEL CT335 Hydraulic hose ruptured #2
rubber hyd hose or steel line ?
   / FEL CT335 Hydraulic hose ruptured #3
that is a steel line. I don't believe the Bobcat loader and Kioti loader are the same. They won't share that line. Any chance of welding it. What happened to it?
Might be right on the steel line, looking at the drawing again 7183002 might be the right part....it's the 4 rubber hoses that connect to the valve body.
Hose ruptured doing some grading work, wasn't too extreme, just burst when it was under load after a few hours of work. Tractor is 10 years old, so could be age.
   / FEL CT335 Hydraulic hose ruptured #5
If its the rubber hyd line you can take it to the hyd shop have new ones made OR the steel line to a welding shop....
Cool, thanks. Off to Napa I go.
Just to close this up, NAPA made a new hose, didn't have the wrap but that's OK, re-connected and back to normal.
Thanks again.
   / FEL CT335 Hydraulic hose ruptured #9
Great....:thumbsup:
2014 INTERNATIONAL LF687(INOPERABLE) (A50854)
2014 INTERNATIONAL...
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A51219)
2018 INTERNATIONAL...
2020 MACK PINNACLE (INOPERABLE) (A50854)
2020 MACK PINNACLE...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2014 PETERBILT 367 (A50854)
2014 PETERBILT 367...
2018 VOLVO VNL TANDEM AXLE SLEEPER (A51222)
2018 VOLVO VNL...
