FEL drops if you try to lift and curl
   / FEL drops if you try to lift and curl #11
Yes I got what he trying to do. Now how would it work if the regen was on the boom spool?
   / FEL drops if you try to lift and curl #12
If he hooked the boom up to the curl work ports, the boom would work normal, and if he then went to regen, the boom would drop faster than before.
We also don't know if regen is in the first part of lever movement, and if it is, then the lift would start to descend faster than normal at the start of lever movement.
   / FEL drops if you try to lift and curl #13
That boom is heavy and drop at a good rate. If the regen is 2nd half he would have to go past the detent and to get the movement that he's trying could not be done. It take very little movement one way or the other to do it. When everthing right it still takes some seat time to do it good. I think he has the seat time by the way he is talking. Hope maybe what is been said well give him some insite and help.
   / FEL drops if you try to lift and curl #14
Was this issue ever fixed Im having the same issue on my tractor?
2020 MACK PINNACLE (A58214)
2020 MACK PINNACLE...
Toro Sand Pro (A56859)
CFG Industry H15R Mini Excavator (A57149)
CFG Industry H15R...
2018 Komatsu GD655-6 Motor Grader, S/N 60403, PIN# KMTGD032PJA060403, Turbo Diesel Engine, 14' (A59076)
2018 Komatsu...
167 (A52708)
167 (A52708)
2018 JOHN DEERE 60G EXCAVATOR (A52709)
2018 JOHN DEERE...
