FEL Hydraulic Problem
   / FEL Hydraulic Problem #1
Bill06238
CT
Kubota B7200 HST
I have a 4ft FEL on my Kubota B7200. The boom will not stay up with the bucket loaded or unloaded. I checked the pressure relief valve setting, it was set low and reset it to 1500psi. The bucket still lowers at about 3/4" per minute. I dead headed a pressure gage into a working port on the valve and found that when the valve is opened the pressure is 1450 psi and when the valve is closed the pressure in the line drops down to 0 psi. Could the valve spools be worn to the point that the valve will not hold the pressure? What elese can I check?
   / FEL Hydraulic Problem #2
MY JD drops too. But more like 3 inches per hour under load. I don't get under it.
   / FEL Hydraulic Problem #3
That does sound excessive. If you're not seeing any fluid leaking it could be the piston packing leaking by or as you mentioned, the valving. You might try Kubotas site to see if there's anything listed as to acceptable drop. If not, ask your dealer they should know.
2004 TRAVIS BODY & TRAILER ALUMINUM BELLY DUMP (A58214)
2004 TRAVIS BODY &...
(2) UNUSED 460/85R30 TRACTOR TIRES / WHEELS (A57192)
(2) UNUSED...
2018 ARIENS RIDING MOWER (A56859)
2018 ARIENS RIDING...
Topsoil Trommel (A57453)
Topsoil Trommel...
2006 Dodge Ram Pickup (A56858)
2006 Dodge Ram...
2018 MACK CHU613 (INOPERABLE) (A58214)
2018 MACK CHU613...
