FEL hydraulics - hard hydraulic line replacement
   / FEL hydraulics - hard hydraulic line replacement #1
Mike52
Glen Mills, PA
Massey Ferguson 220 Compact Diesel
I have an MF 220 with a small Massey loader. The hard hydraulic lines on it are pretty rusted, and dinged up. Anyone know of a firm that can sell me replacements or build new ones? Or, am I better off getting the tubing bender out and making a set myself?
   / FEL hydraulics - hard hydraulic line replacement #2
Any local hydraulic shop can make new ones for you, probably less expensively than purchasing new ones from MF. You will need more than a tubing bender to make the proper end fittings. Check the local Yellow Pages for your nearest hydraulic shop.
   / FEL hydraulics - hard hydraulic line replacement #3
Or if you want to get rid of the steel hard lines altogether you can just fab up some replacement flexible hydraulic lines yourself using the replaceable type end fitting's.
Personally I would get new steel lines made up. They last ALOT longer and are much more damage resistant. Like stated previously, check the yellow pages for a local hydraulic shop.
   / FEL hydraulics - hard hydraulic line replacement #4
Take your old lines to NAPA. they can make up new stainless lines with flared fittings.
   / FEL hydraulics - hard hydraulic line replacement #5
you do relize that new hardlines are considered to be plantum plated when it comes to cost right?!?!
thanks gents....I'm off to NAPA
JOHN DEERE 3020 TRACTOR (A51247)
JOHN DEERE 3020...
6" CONVEYOR BELT (A54757)
6" CONVEYOR BELT...
2021 KENWORTH T270 (A55745)
2021 KENWORTH T270...
2007 Ford F-150 Crew Cab Pickup Truck (A53422)
2007 Ford F-150...
200722 (A51247)
200722 (A51247)
JOHN DEERE HPX GATOR 4x4 *NOT RUNNING* (A50324)
JOHN DEERE HPX...
