CaliforniaIt seems to me it would be easy to create this sort of overload bouncing on rough ground with a heavy load.
Do any tractors have overload relief in each separate circuit?[/QUOTE said:
I made a comment earlier in this thread that I thought the relief valves would take out the shock. However, upon looking at the parts diagram (because my tractor is too far away) it appears that the relief valve on the control unit may only serve to relieve excess pump pressure when attempting to lift a too heavy load. (As also does the relief valve at the pump itself). It appears on the surface then that theres nothing to take the shock off the loader. But then again, the parts diagram doesn't show the internal design of the control unit so perhaps the 'backpressure' from a bouncy loader is plumbed back to the relief valve somehow. It would seem sensible to me that some sort of pressure release is built into the loader/bucket circuit.
