FEL Pallet Forks / Carry All - Another Build
   / FEL Pallet Forks / Carry All - Another Build #1
nate_m
South West OHIO
JD 2520
Spent my weekend in the shop putting these together. Used 2 x 2 box for the frame and 3 x 5 angle for the forks. (It was all free from the dumpster at work)
Works with the QA on my 200CX FEL and also with my QH on the 3PT.
Thanks to all who have previously posted pics of their builds/buys. These were a great resource to have as I put mine together.
Also, my thanks to those who suggested using a log splitter as a press to bend steel. That was the best part of this build; seeing the splitter effortlessly put the 45* bends in the upper support. Great trick to have. No more heating with torch and beating with hammer for me!
   / FEL Pallet Forks / Carry All - Another Build #2
Looks great, and thanks for passing that bending tip on, never heard that one, I've got a splitter and will have to try it.
   / FEL Pallet Forks / Carry All - Another Build #3
Nate,
I really like the fact that you made your forks versatile to fit both the front FEL and the rear 3pt.
They look great!
   / FEL Pallet Forks / Carry All - Another Build #4
Nice job!:D It pays to check the dumpsters at work!
   / FEL Pallet Forks / Carry All - Another Build #5
Nice job there! I am thinking of building the same for my 2210, but much smaller scale though. What thickest if material did you use?
Dan
Dan
Thanks, Dan.
I used 1/4" for all the frame pieces. The angle iron for the forks is 3/8". Probably overkill for the lifting capacity of my FEL.
   / FEL Pallet Forks / Carry All - Another Build #9
Those forks are great but I am really digging the way you move your split wood around
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A55315)
GALAXY - SET OF...
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
2006 Keystone Laredo 29RL 31ft. T/A 5th Wheel Travel Trailer (A55853)
2006 Keystone...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
(APPROX. 26) 4' X 8' X 3/4" OSB SHEETS (A52706)
(APPROX. 26) 4' X...
2008 CMTL 19ft Homemade Travel Trailer (A55973)
2008 CMTL 19ft...
