FEL quick connect covers won't stay put
   / FEL quick connect covers won't stay put #1
hazmat
Elite Member
West Newbury, MA & Harrison, ME
Kubota L5460HSTC
FEL quick connect covers won\'t stay put
3 of the four won't stay on. Are these things a "wear item" - Ie do I need to replace them every couple years.
   / FEL quick connect covers won't stay put #2
Re: FEL quick connect covers won\'t stay put
I usually have to pop mine with the heal of my hand a couple of times to get them to seat/pop in properly. Mine do fit tight, so if they fall out, I didn't get them seated properly in the first place. These are the ones on the tractor right?
I have never had any wear out. If they are loose, could they be weathered(hardened) /forums/images/graemlins/confused.gif, so they don't spring back to a tight fit. This would go for both the plugs on the tractor and the boots on the hoses.
Otherwise I dunno, hope this helps at little.
   / FEL quick connect covers won't stay put #3
Mine are about a year old and they have always remained in place. Considering some of the places that I work I can only imagine the dirt that the the quick connects might accumulate without them. It couldn't be too good for the hydraulic circuit.
yup tractor side.
I'll try the bigger hammer approach - ie push them on harder.
   / FEL quick connect covers won't stay put #5
Do you pull the collar back on the female connectors and then push the rubber plug in? I have had better luck that way - two years and still pluggin' OK on my TC40D.
   / FEL quick connect covers won't stay put #6
<font color="blue"> Do you pull the collar back on the female connectors and then push the rubber plug in? I have had better luck that way - two years and still pluggin' OK on my TC40D.
</font>
Chris I thought for a second that you were pulling my leg. I have always just tapped the rubber plug in place on my TC-40D with the palm of my hand but after reading your post I wandered out to my TC-40D and tried it your way. And I admit that your way is better than my way. It takes no effort to seat them if you retract the collar first. Thanks /forums/images/graemlins/grin.gif
2013 Chevrolet Impala Sedan (A51694)
2013 Chevrolet...
2018 Sakai SW990-1 Tandem Vib Roller (A52384)
2018 Sakai SW990-1...
2014 Chevrolet Spark Hatchback (A50324)
2014 Chevrolet...
2010 Chevrolet Equinox SUV (A51694)
2010 Chevrolet...
New/Unused 12ft x 7.4ft x 8.2ft Container (A51573)
New/Unused 12ft x...
2015 KENWORTH T370 QUINT AXLE DUMP TRUCK (A52576)
2015 KENWORTH T370...
