Snow Attachments FEL snow plow vs frame mounted
   / FEL snow plow vs frame mounted #11
Don,
It looks like this plow has adjustable skid shoes. What I did when I had the Kub hyd angle plow on my B7610 was to lower the skid shoes so that the blade was about 1/4" above the pavement. When you start to push snow, it seems to push the blade down enough to get a good clean scrape. No chatter and no problems.
I realize the Curtis and loader arm arrangement is different than the Kubota Quick Hitch set up. But the skid shoe adjustment still may be the easier way to a smooth operating plow.
BTW: I have a Frontier power angle blade for my new Deere that works almost exactly the way your Curtis does. I am looking forward to putting it to use this winter.
KB
   / FEL snow plow vs frame mounted #12
nedly05 said:
New cutting edges will make you chatter like that too, once it brakes in or get a "bevel" on the bottom so to speak it will not chatter so bad, probably mostly the chatter is from the dry blacktop. I am looking for a blade to build my own plow!!
exactly what I was going to say. Even truck mounted plows do that until they wear a bit. And dry pavement and snow plows are a bad mix.
   / FEL snow plow vs frame mounted #13
I had a kubota subframe mounted #2019 front power angle blade on my b7500. It was one of the best plows i have ever owned!
2007 Kenworth T800 Tri Axle Day Cab Truck Tractor (A56858)
2007 Kenworth T800...
2010 Hyundai Elantra Touring Sedan (A55853)
2010 Hyundai...
2007 Ford F-450 4x4 Cab and Chassis Truck (A55852)
2007 Ford F-450...
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
2015 Ford Explorer AWD SUV (A55853)
2015 Ford Explorer...
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
