FEL Techniques
   / FEL Techniques #11
I know what you mean! I'm kinda a beginner with the Fel myself, just yesterday I attempt to load from a large 5 ft x 10ft wide pile of leafs I've been gathering to put in the Garden, the 1 st go at them only pushed the pile over very little went into the bucket the second attempt I laid the bucket level with the ground and then got what i thought was a full scoop, but when I dump them was only about half bucket, :(
I'm moving these leafs from a pile 200 ft away from the garden spot, many trips would be needed, I've come to realize because of the leafs being so light weight and not easily loaded I've decided to simply rake them into the bucket and then move them over to the garden although this will be a lot of off andon the tractor ;) so actually I may simply rake them onto a large tarp and drag them over there all at one time:D so much for the convenience of having a FEL.
some task are just not worth the hassle of trying to use a FEL,:cool:
On another note: it took me a while to get the hang of using a single joystick ya know the thing of being up is down down is up, left curl up right curl down :eek:
though I have got quite handy at scooping up dirt, I find if you go into the ground at about 2" or at approx 10/15* angle and pull straight forward until the tire just start to break traction I can then curl the bucket back to being level with the ground and finish pulling forward grabbing a full scoop then go to full curl lift and drive away, having a tooth bar would help break the soil loose before scooping,
I have also learned to back drag the driveway although not as have been suggest to me by using the heal of the bucket, this just made the tractor hop and spin wheels resulting in digging ruts, I can however drop the front cutting edge of the bucket just enough to barely lift the tractors front end i then locked the diffy and back dragged until it was nice and smooth,
.........as said before "practice makes perfect" :)
   / FEL Techniques #12
Moving brush with a bucket is a pain, but if that's all you have it can be done. I pile the brush or push it into a pile so all the sapplings, limbs etc. are parallel to each other. Then I push the pile from the side with the cutting edge of the bucket raised just slightly off the ground. Sometimes it will start to roll under the bucket, you have to back up and get below it again. It will make a fairly tight roll after a bit that hangs together. A big pile is easier to push than a small one.
Never cut brush and sapplings into short pieces if you intend to push them with the tractor bucket. You will chase those forever and probably end up gathering them by hand. Keep things at least 8' long. 12' to 15' is even better.
Logs are easier to move by pushing on either end rather than the side if you are going any distance. You can steer them a bit too. Watch out for too much speed, if the log you are pushing gets stuck it will jump sideways in your bucket. This is hard on equipment and will jerk the front of tractor to the side too.
Obviously a grapple would be nice to have, especially if you want to move things more than 100'-200'.
Dave.
   / FEL Techniques
Thanks for the tips so far. Keep 'em coming. Few more questions:
1. Explain more how the float function can help with some of the jobs. I have that setting, kinda know how to get there, but have not tried it.
2. I thought the pushing with bucket completely dropped might put the FEL in an awkward postion pushing forward. What about using it to pull things backward, and level, as has been mentioned. I have used it that way several time.
3. I will look into some bucket attachments, like tooth bar, forks. At this point I am trying to use the equipment I have.
4. What is a "floppy bucket"
5. Thanks for the rpm tip. I have probably been operating at rpm too low
   / FEL Techniques #14
I'd suggest the first thing you do with the bucket is cut off the existing cutting edge and replace it with some 1/2 by 4or6 inch. cutting edge. Do the front edge on the sides too. Also place several strips on the bottom.
That will really stiffen up the bucket.:D
   / FEL Techniques #15
Float is good for back blading since in that mode the bucket is free to follow the ground under its own weight. Since you are not pushing it down with the tractor the front wheels are still effective for steering. You can vary the bucket tip angle to adjust the aggressivenes of action. There is some danger of bending a cyl rod when backblading at hi tip angle because the geometry of the pivots multiplies the force pushing on the rod, so be careful especially if not using float and instead pushing down with the weight of the tractor while backing... or pulling logs backward etc. A bucket tipped way down in these cases is verry stressful. The setup on my 7520 seems to be be able to take it, but there are plenty of stories of rod damage on the forum.
Seldom would you use float when pushing forward. Its a little touchy because the arms want to knuckle under.
Floppy bucket is when hydraulic fluid does not completely fill both sides of the cyl ram. It can occur after dumping a heavy load because the fluid in front/rod side of the ram is forced out by the dump weight faster than your control valve replenishes the back side. The result is an unfilled volume on the back. Cycling the hydraulics will bring it back ti normal.
larry
   / FEL Techniques #16
Back blading works very well using the heal of the bucket and it being half full of material when using float. It then has more weight on the heal so it cuts more effectively. Its also handy when you have a hole or low spot as you already have material in the bucket to fill it.
You can also have it almost flat as well if the material is wet or sticky enough not to roll out of the bucket.
2022 Freighliner M2 4 Car Rollback (A53117)
2022 Freighliner...
2014 Freightliner M2 106 Medium Duty Passenger Bus (A51692)
2014 Freightliner...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
City of Buckhannon Onan 200 Set Stand By Generator (A52384)
City of Buckhannon...
Pitts Tri-Axle RGN Lowboy Equipment Trailer (A50322)
Pitts Tri-Axle RGN...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
