FEL, TORO Groundsmaster Put Together
   / FEL, TORO Groundsmaster Put Together
Took it to a hydraulic shop to get hoses made. Here are pictures from 8-17-2005, if you right click on the pictures, you can open them in a new tab or window, depending on your browser.
Hoses on, it works!
8-18-2005 Made this fork carriage many years previous for an old Craftsman loader.
Works on this one, using longer pins. I later added angle iron to support a shorter pin the normal way.
Boom pole on the forks.
9-2-2005 Wheel(less)barrow on the forks with a load for the recycle pile.
Brinly cat 0 A Frame bolted through the holes in the forks that came with it many years ago.
4' cat 0 box blade
8-24-2005 Had this old tractor brushguard in my scrap pile, so I welded a piece of 2 inch square tubing to it, so that it would fit in the receiver hitch.P8241944.JPGP8241946.JPGP8241947.JPGP8241948.JPGP8241949.JPG
11-7-2005 Ten sacks of horse feed. Notice the old Craftsman Loader for sale by the fence. I was going to use it, but got this wider KW loader.
11-10-2005
P.S. it was dry dirt!
Forking brush:)
7-22-06 Removed the receiver hitch from the Toro, modified the brushguard to bolt on where the hitch was, and built a receiver hitch into the brushguard.
That is a 100 pound block of steel laying between the brushguard and the frame.
Two 100 pound tractor weights.
11-30-2005 Added a guard to prevent full speed forward, when it touches a tree trunk at the edge of the burn pile. Guess how I know it would do that! :laughing:
12-11-2005 Cut a 90° conduit, put it over the cut off exhaust pipe, to keep the brushguard cleaner.
This happened 8-9-2006. Was using the forks to knock the dirt off of the root ball on a willow tree that the dozer dozed. Backed up, but it didn't turn uphill, because the right front tire was almost flat (slow leak). The right front dropped into a hole, and the Toro went over, I fell off of the seat onto the side panel. The engine was still running, I had to raise up and reach under my butt to turn off the key. I was right at the edge of the water, the loader tower was in the water. I got my tractor, put a chain on the left loader arm and pulled it upright.
Looking south from the dam.
Bottom view.
Rear view.
Front view.
This is the root ball I was knocking the dirt off of.
Notice the 100 pound block of steel at the lower right, that fell off of the brushguard.
I left it chained to the tractor, got on, crossed my fingers, it started and I backed up the hill.
The loader wasn't up very high and the hole wasn't very big, but it sure went over fast.
Another use for the forks, 5-10-2009.
   / FEL, TORO Groundsmaster Put Together #18
That's a nice little toy, er tool. Looks very useful to have around.
Thanks, it is both a toy and a tool, but not a toy tool.:D
I have used it a lot, some of the dead trees in that burn pile were pulled by the MF240D, but it didn't have a loader, so the pile was made with the TORO.
   / FEL, TORO Groundsmaster Put Together #20
Cool build, how much can you lift?
2021 WANCO, INC LIGHT PLANT (A58216)
2021 WANCO, INC...
2015 Vermeer VX30-500 Gallon Tandem Axle Vacuum Excavation Unit (A59213)
2015 Vermeer...
Unused 2025 CFG Industrial MH12RX Mini Excavator (A59228)
Unused 2025 CFG...
DECORATIVE METAL GATE (A58214)
DECORATIVE METAL...
2003 CHEVROLET 2500 HD SINGLE CAB TRUCK (A58375)
2003 CHEVROLET...
Caterpillar D5G LGP (A53317)
Caterpillar D5G...
