Fence Building - Barb Wire Racks
   / Fence Building - Barb Wire Racks #11
Gary, the way they use the plow discs is to keep the rolls separate while unrolling.
Thirty years ago I bid on a great big job, hundred miles or so. It was five strands of barbwire with t posts and braces in California. When I went to the pre-bid I realized I'd stepped out of my league. This was a phase three of a continuing job. The boys doing it had miles of experience to work out the bugs.
What they had was wire holder that held tension along with a post driver. This was on a small crawler, D-3 if I remember right. They had one crawler clearing the right of way and setting braces. That was followed with the wire dispenser post pounding rig. A third crawler followed doing clean up.
Here's some ideas for you to consider.
One, the pilot rod should be hex bar. Then the separator plates should have hex holes to match the bar. I would weld tabs on both sides of separator plates that will grip the rolls of wire. These could and should be short so that they engage only the wire frame and not the barb wire itself.
Two, I'd want the hex bar to have a mechanism that allowed the tension to be adjustable. I'm thinking a sleeve that fits over the hex bar and with a coarse acme style thread with threaded collar to tightening. For tension I'd rig a disc brake assembly like that found on small motorcycles or go karts. Cable would work, hydraulic would probably be better.
The hiccups are of course uneven terrain and different factory tensions in the rolls of wire. This might be compensated for with a stand off rod or bar like that found on the Wire Hog or a comparable product.
A friend of mine does a lot of farm fence and he just uses pipe with plow discs for separating so if you're not going to make this job a career that might be the place to start.
James, I'm glad you like the wire unroller. I heard the other day people are now buying shirts without pockets. What's this world coming to?
100 miles of fence? Now that would be some project.
I've about three to four thousand feet left to build in the next year or so. I think I'll stick with a three or four roll non-tensioned design and just let it lay on the ground where it falls. I'll tension up each wire separately by come-a-long as usual. I think if you lay out any more than that without keeping tension on them, they will get tangled up beyond all hope. Plus, if I keep the rack small, I can put it in the back of the Polaris Ranger which should be small enough to weave in and out of the trees. For a nine wire run, which is the most I’ll ever do, I’ll have to make three runs down the fence line, but since I’m a small time fence builder, that’s okay.
BTW, my new welding trailer made Millers latest Powerclick e-publication under Shop Talk. Last time I looked, the post had over 6000 hits.
PowerClickIssue82006
2017 Ford Taurus Sedan (A51694)
2017 Ford Taurus...
2006 Kobelco SK210LC Hydraulic Excavator (A52377)
2006 Kobelco...
2017 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A52377)
2017 Chevrolet...
2005 Nissan Pathfinder SUV (A53424)
2005 Nissan...
2020 Nissan Pathfinder SUV (A51694)
2020 Nissan...
CUSHMAN GOLFCART (A51406)
CUSHMAN GOLFCART...
