Ferguson TO30 Hydraulic Problem
   / Ferguson TO30 Hydraulic Problem
Thanks, I'll take a look at it. I appreciate the advice!
   / Ferguson TO30 Hydraulic Problem #12
I'd check the t valve. sounds like the intake is stuck / sticky..
soundguy
Is there a sketch or pic of how the t valve is accessed and how it is positioned (ie. in relation to the control lever? I would like to see one. Thanks.
   / Ferguson TO30 Hydraulic Problem #13
it only moves in and out.. :)
   / Ferguson TO30 Hydraulic Problem #14
I've got a problem with my TO30 My lift doesn't work unless my PTO is running and its either all the way up or down no in between I just bought the tractor and it is in real bad shape I'm working on fixing everything but I need to find a book on it can anyone point me in the right direction
   / Ferguson TO30 Hydraulic Problem #15
service manual is availa at tractor supply and online.
newsflash!
yer fergy t0-30 has non live hyds via a belly pump.. the pto runs that belly pump.. thus pto has to be running to have hyds.
also.. you have draft control hyds ONLY.. no position control. due to this your lift will seemingly act like it has only all the way up or all he way down/. takes a light hand to find the middle. if you are completely unable to find a middle.. the lift cover needs a lil adjustment. most people with fergy's and 9n/2n fords invest in some depth limit chains and put them on brush hogs and just lift for transport then drop onto the chains for mowing..
22in Frost Bucket (A59213)
22in Frost Bucket...
2015 Ford Escape SE (A57148)
2015 Ford Escape...
2017 Polaris Outlander 1000 4-Wheeler (A57149)
2017 Polaris...
2015 CATERPILLAR 140M3 MOTOR GRADER (A58214)
2015 CATERPILLAR...
2012 BIG TEX PIPE TRAILER (A58214)
2012 BIG TEX PIPE...
excavator trenching bucket- one bucket per lot (A56436)
excavator...
