Ferguson Tractor
   / Ferguson Tractor #1
bironacad
Platinum Member
Southern Ontario, Can
New Holland 3045/2010
I came across a older tractor abandoned in a corner of a building lot. Wondered if there was some experience out there with this particular type tractor and would it be worth playing with? What year it might be? Any general information on the tractor?
   / Ferguson Tractor #2
I think the tractor would be worth playing with or restoring. They are very similar to the 8n Ford. It looks to be all there and the tire look to be in good shape. These tractor were made in the 40's and 50's. They produced about 20hp. I believe they had a four speed transmission and weigh about 3500lbs.
If you can get the model off the serial plate it would be useful because there are 6 different models of the tractor that look similar.Also if you get the serial number we can find the year of it.
They are the TE-20 TEA-20 TEF-20 TO-20 TO-30 TO-35
These tractor had the Ferguson system(3 point hitch) and there is plenty of these tractor around.
   / Ferguson Tractor #3
On the 1 I owned (TO 20). The serial # plate was on the dash
   / Ferguson Tractor #4
You should try yesterdays tractor for older models. Tons of info at ytmag.com
   / Ferguson Tractor #5
I have a TO 30 30 HP tractor, that had a cracked block, which is a common problem with the Continental z-129 engine.. I put more into getting a block and having the engine completely rebuilt than the tractor was really worth, but i do not regret it , its a great tractor, and will out perform and out last them little yuppie 27hp diesels today ! Any questions feel free to ask I maybe able to point you in the right direction. Yesterdays tractors is where i got all the engine parts to rebuild it.. IF its a TE model instead of a TO beware its an English model and parts are harder to find on them models, since they are a little different ! The ID plate is right on the dash with the model..
   / Ferguson Tractor
I did the same with the international that is in my avatar, now gone, but I got to play with it for several years. My uncle gave it to me with a cracked head and block, my cousin rebuilt the engine for $2600 I got $500 on a trade, lol.
   / Ferguson Tractor #7
No experience with this particular tractor, but I do own a 1964 MF135 diesel that I've reconditioned and am now rebuilding a 1951 Minneapolis Moline BF tractor which is similar in size and engine hp to that Ferguson you're eyeballing.
That Ferguson has money pit written all over it since it's been sitting in the weeds for who knows how long. As an example, it cost me $1600 ($800 parts, $800 labor) to get the Hercules engine in the BF completely rebuilt (it had zero compression on all 4 cylinders). By the time I finish the BF restoration, I'll have about $4500 in it (I paid $1300 for it).
Unless you really, really want a Ferguson restoration project, I'd keep looking.
   / Ferguson Tractor
You are definitely spot on. Just seems like such a waste.
   / Ferguson Tractor #9
It could be a money pit, on the other hand it could need very little.
Your first step is to try to find out who owns it. If it is not sitting on your private property, I don't know the legality of just taking it. But if it is truly abandoned, then maybe you are ok to liberate it.
But on the other hand, it is probably a really terrible broke down piece of equipment and I think you should tell me where it is so I can't get the unsightly thing out of there.... ha ha.
   / Ferguson Tractor
Hey it is at Morningside and Finch North West corner just west of the railway line.:thumbsup:
   / Ferguson Tractor #11
It look like a TO 20 or it could be a TE 20. I have a TE 20 paid 500.00 for it and it had been sitting about 15 years. I had to rewire it and add antifreeze to it as the radiator had been drained. I put a battery in it and it rolled ove a few times and started right up. I changed all the fluids in it and have been using it since. Only money I had to put in it was a new water pump. The TO series was built in the USA and had a delco starter and dis. The TE was built in England and Has a Luscas electrical system. Mine starts up below zezo and it is fun to drive. Ivan
   / Ferguson Tractor #12
Hey, I live in Northern Minnesota. What would yoou charge to ship that hood?:laughing: I just traded work for a TO20. My first tractor, but looks like it will be fun.
   / Ferguson Tractor #13
I have a question for restoration guys. It concerns a ferguson TO20, thats why I am asking here. My tractor has good looking sheet metal (well, mostly, the grills a little gimped up, but it shouldn't be to bad), therefore, I am considering doing a restore. First off, I am trying to find factory paint color. All the pictures I have seen show completely gray machines, but mine has red fenders and hood. Complete opposite of an 8N, It is a To20 with a serial #49XXX, which I believe makes it a '51 or '53 That is kinda throwing me, though for now I just want the drivetrain color. I have found a few companies that had what they indicated was a macthing Ferguson gray, but they sounded sketchy to me. One site said I could use Rustoleum #975, that that would match. Restorer, what do you have to say?
   / Ferguson Tractor #14
damanishere I believe that the tractor has probably been repainted to look like a Ferguson 35. From the serial number 49xxx I think it would be a 1951 as you stated. The paint scheme is all Grey.
As for paint Tractor supply has the Valspar restoration series paint which is a automotive grade with a shiny finish and good resistance to fading . On my Case Sc it has the restoration quality paint and it has a good gloss finish.
You can take a look at the paint breakdown here.
http://www.fergusonenthusiasts.com/restoration helps/paint/Paintschemes.pdf
   / Ferguson Tractor #15
Thanks for the info. That makes an easier paint, but a rather dull looking tractor:( How many gallons of paint will I need if a good prep job is done?
2020 INTERNATIONAL MV607 26 FT BOX TRUCK (A59905)
2020 INTERNATIONAL...
UNUSED FUTURE WALK BEHIND POWER TROWELL (A52706)
UNUSED FUTURE WALK...
2017 Ford F-550 (A55973)
2017 Ford F-550...
2017 Bobcat T770 Compact Track Loader (A56438)
2017 Bobcat T770...
5ft Rotary Brush Cutter Tractor Attachment (A59228)
5ft Rotary Brush...
2013 COACHMEN CATALINA TRAVEL TRAILER (A55745)
2013 COACHMEN...
