MMagis
Veteran Member
You're right, I worded that wrong. What I meant was there wasn't a reason to separtate them by weeks. Personally, I think that seed, fertilizer, and lime should all be spread separately for that very reason. That's actually an important thing no one has mentioned yet. Grass seed is not going to spread the same as fertilizer or lime. It most definitely should be spread by itself.But you have to make sure the rate of application is correct for each when you mix up the blend. And if the weight and granularity of the materials being blended is very different, you can get an uneven spread. Fine fertilizer particles and coarse lime granules won't get thrown the same distance in a rotary spreader, for example. Likewise for mixing fert and grass seed.
