Dadnatron
Veteran Member
My son was put to work, helping me remove fence and pull trees last summer. He did a good job, but he had an incident with a tree getting away from him because of a grasp with the Intimidator, lower than center of gravity. When he lifted the tree, it rotated on him, pushing the root end into the 'grill'. Well, I've been working 'as is' since that time, with the expectation that I'd fix it later. And now, later has finally arrived (along with hopefully some warmer weather) and I'd like to fix the front of the hood.
There is a chunk which is gone, about 5x4" or so. I've never worked with fiberglass, but it seems well within my wheelhouse. But I wanted to check with you guys about what materials you'd recommend. I'd prefer to purchase the 'EASIEST' kit which will do the job. Basically, I'd like everything I need to get to the prime and paint stage in a kit if there is a good one. Unless there is a real good reason that piecing it together is the clearly superior direction. If all goes well, I have a few other dings and cracks I'd like to fix on the back fender.
I ordered a new headlight bezel and front screen.
I'd appreciate any thoughts on doing this job in the 1. Easiest 2. Best way possible.
