Field Mowing
   / Field Mowing #1
dsb5610
N IL
Deere 4720 Cab
Finally had a chance to run the Toolcat with the 72" mower. Adding an additional strip of foodplots in some CRP ground and the long grasses were not cooperating with the moldboard plow.
I set the mowing height to the highest level (5.5") and cut three mower widths. I only went over it one time and was impressed at how well it did. I ran about 3mph due to the roughness and it did not struggle at all. I did find out the safety shutoff does not work on this unit as I can pick the mower up and it keeps running. I suspect that will be addressed when Bobcat comes out to do the safety notice work.
There was a steady cross wind when I mowed. Sure was nice sitting on the cab watching all the dust floating around outside. Cleaning off the mower was easy too, pick it up, tilt the front of the mower down, shake it a little, brush off what's left and your done.
I'm beginning to think a good solution for mowing the CRP ground at the 10" minimum would be the 90" mower adapted with a custom set of bigger wheels and support bar that allows for higher mowing settings.
Attached is a pic of the unit from the front.
dsb
   / Field Mowing
Pic from the side
   / Field Mowing
Pic from the back
   / Field Mowing
Pic of the finished product
   / Field Mowing #5
DSB,
Looks like youve got plenty of mowing looking at that picture /forums/images/graemlins/grin.gif What size mower are you using?
scotty
   / Field Mowing
This one is a 72". Actually more of a finish mower than a rough cut but this is just tall, thick grasses. Seemed to handle it well. Normally when I cut this I have a 10" minimum I have to follow but this strip will be plowed for foodplots so I cut it short.
dsb
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
RoGator RG1100C (A56438)
RoGator RG1100C...
2018 PINSA 130BBL VACUUM TRAILER (A58214)
2018 PINSA 130BBL...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A56438)
2020 Westfield MKX...
1981 LINK BELT HSP 8028 (A58214)
1981 LINK BELT HSP...
Forklift (A59228)
Forklift (A59228)
