Field Mow'n in Maine - TC18 in action
   / Field Mow'n in Maine - TC18 in action #41
Re: Field Mow\'n in Maine - TC18 in action
I was going to ask the size of your cutter but I now see you stated it is a 48" cut...What is the required PTO horsepower?
thanks...
The woods specs say 15-50 Tractor HP. Don't know if that is PTO or Gross. I have 18.5 gross, 14.5 PTO. I have to slow down in really thick grass. Otherwise it handles it just fine. I think your 4110 should do just fine with a 48" cutter.
   / Field Mow'n in Maine - TC18 in action #43
whatz a woods cost i've narrowed it down i think the lx4-6 are woods since they build the jd frontier line up a new lx4 -5 was 1100-1200 w/o slip clutch. looks like yours has rubber saftey vs chains was that an option? Loved you article..
   / Field Mow'n in Maine - TC18 in action #44
I have a MMM (finish) and have topped off many a rock sticking up from the ground, as well as spitting out loose rocks. I used it to cut down fields, saplings, etc. Have had it/used it for three summers now and have never sharpened the blades and it still gives me an excellent cut.
It was $938 w/o slip clutch (that adds ~$70). Chains added ~$200. The rubber worked well for the field grass. Time will tell if it will hold up. If not, chains it is.
   / Field Mow'n in Maine - TC18 in action #46
I hit a brick on my 6' finish mower it took a good bit out of the blade 2 holes about 1/2" x 1/4" i changed blades i figured it thowed the blades out of balance.
2007 KONECRANE SMV25-1200B STRAIGHT MAST FORKLIFT (A51406)
2007 KONECRANE...
1262 (A50490)
1262 (A50490)
2019 TOP HAT TRAILER 20 FOOT UTILITY TRAILER (A53843)
2019 TOP HAT...
2014 DRAGON PRODUCTS 130BBL VACUUM TRAILER (A53843)
2014 DRAGON...
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A53473)
2017 KINZE...
2005 CHALLENGER 500 BBL FRAC TANK (A53843)
2005 CHALLENGER...
