ovrszd
Epic Contributor
- Joined
- May 27, 2006
- Messages
- 33,727
- Location
- Missouri
- Tractor
- Kubota M9540, Ford 3910FWD, Ford 555A, JD2210
It is called Paralysis by Analysis and it permeates all of society unfortunately.
But if you want to get technical, to me; you are going about it all wrong. Fluid filled tires might lower the center of gravity somewhat, but that is about all it does.
If you want to get into physics, it is waste of time to discuss fluid-filled tires because the net gain is so low. A tractor owner has a very limited space in which to add weight (fluid), the ability to make that area more dense with liquid is very limited, and it is in a very non-effective area...which is right over the rear axle.
If a person wants to be effective, they want to get weight out PAST the rear axle, this is called leverage, and the weight transfer shifted past the rear axle is going to counteract the weight in the bucket in proportion cubed to the distance moved from the rear axle. It is as simple as, 250 pounds of weight six feet past the rear axle is going to be more effective at counteracting the weight in the front bucket, than 500 pounds of weight in the rear tires.
Look at a tower crane. To lift heavy loads they do not fill the tower base with water, they shift weight further aft to counteract the load.
It is not rocket science, and with adding counterweight to the back, there are so many more options. A tractor owner can add more weight, change the shape of the counterweight, use denser materials for greater weight, or shift it further aft more.
We used to fluid-fill tires too, but it is a very expensive way to get minimal results.
I should have read down before I posted the first time.
Again, your statements sound very inexperienced. I added 1350lbs of weight to my tractor for .15 per pound with tire fluid. The results were way beyond minimal. :confused3:
