Fill-Rite pump issue
/ Fill-Rite pump issue #1
cef2lion
Central PA
JD 4410, JD455
Friend has a Fill-Rite FR600C 115V transfer pump that quick working. pump doesn't run. bypassed the switch where nozzle sits. Any ideas?
Craig
Thanks for the info and diagram. Is there a method to try and free brushes or impeller?
/ Fill-Rite pump issue #4
Take off end plate from impeller end and try turning the impeller and shaft. This will also turn the commutator on the brushes. May free it up, but just short term solution. Probably needs a rebuild kit. As the brushes wear they begin to stick, and could ruin your armature.
/ Fill-Rite pump issue #5
i need to replace those brushes, where can i find those?
/ Fill-Rite pump issue #6
I would start with the Yellow Pages and look for a Fill-Rite distributor. Should be listed under pumps or petroleum equipment. Also might try a NAPA dealer if you have one nearby.:)
Took plate off the end. Pump and motor turn freely. Measured power to shutoff switch. That switch is good. Was able to measure power to connectors on end off motor. Not sure how you get the bushes out? Are any of the electrical parts replacable under end plate or does it seem like a brush or motor issue?
Checked out the part diagram. Part on end of motor is thermal protector. There is also a rectifier listed. The line switch tested ok. As started the motor and pump turn freely. Not sure how to take brushes out to inspect them.
/ Fill-Rite pump issue #10
You have to open up the motor. The brushes are behind end plate on electrical end and brush holders are held in with a screw.
20023 KAWASAKI BAYOU 300 ATV (A64281)
20023 KAWASAKI...
UNUSED (15) SDLANCH PROTECTION MATS (A64281)
UNUSED (15)...
2016 Ford Explorer AWD SUV (A61574)
2016 Ford Explorer...
Tufline PT 12' Box Blade (A64119)
Tufline PT 12' Box...
Towable Dual-Line Pipe Road Crossing Trailer (A63689)
Towable Dual-Line...
2017 Ford E-Series FedEx Delivery Truck, 5.4L V8, Step Van Conversion (A63689)
2017 Ford E-Series...
