Filled Rear Tire Meets 16-Pennies
   / Filled Rear Tire Meets 16-Pennies #21
Let's define kits. You can get the full blown kit with Reamer, Push needle, plugs ans GLUE. You can also get replacement plugs and varrious tools.
I bought a "kit" at NAPA that had the reamer, pusher, and wormy plugs. Tools had tiny, screwdriver-like handles. Never did get a plug to stay.
Then I bought a DIFFERENT kit at Knecht's which had tools with t-handles, wormy plugs, and also a tube of patch cement. Using the glue as lubricant during both the reaming and insertion made the job easy despite the fact I was going clear through an R4 lug. This kit was made by Monkey Grip.
-ml
   / Filled Rear Tire Meets 16-Pennies #23
When you/they put in the tube, finally, try to knife off the plug(s) sticking in so they don't abrade the tube. Also, you should be able to tell the difference between a tubed tire and tubeless by the valve
this one is a tractor tubeless. It has a second "cap" that allows you to run in the liquid without going through the Schrader valve. Tubed tires usually you just see the rubber tube.
Jim
Well, JimmySisson, I wish it was as you say -- and I wish that tubes had been used. But I bought the tractor in a part of California where freezing is not an issue, and neither are hills. The dealer had not filled a tire before when freezing might be an issue. Their local tire place did the job though. Not, apparently, up to standards for hill country. For now, I'm pleased as punch that my tire is fixed, and I'm saving my money for a good set of chains.
Thanks for your reply, the tip, and the picture of the valves I wish I had.
-ml
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A52748)
2017 Yale GLC050VX...
MILLER BIG BLUE 500 PRO TOWABLE WELDER (A52472)
MILLER BIG BLUE...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
1992 Peterbilt 377 Sleeper Cab (A52748)
1992 Peterbilt 377...
2018 John Deere 1653 (A52748)
2018 John Deere...
