BHD
Veteran Member
I have need of a slip roller at least 50" wide, and would like to be able to do 10 gauge, and would like to use it for rolling rings out of flat as well, at the ends, of the machine,
I have looked online and most start in at $800 and up fast, and there only rated for 16 gauge,
first if I would order in steel shafting of 4" I am reasonable sure my costs would start to rival a bought unit,
so the thought I have is to use heavy wall pipe (thinking 4" in diameter or near that), and a 1.5 shaft (or near that) running from end to end, with filler rings on the ends, to support the pipe, (hoping I can find some type of drill stem some where).
HERE IS THE QUESITON, is there any filler material I could pour in the center of the pipe to make it solid that would not disintegrate to dust in time, (like concrete) the idea is to make the pipe work like solid shaft,
any type of epoxy type filler that would be affordable?
the rollers will flex some on heaver gauges,
