Filling new oil fiter before installing
   / Filling new oil fiter before installing #11
With gas car/truck engines I've always filled every filter, keep letting it soak in and top it up as much as needed until it doesn't absorb any more - and I can still get the filter on without spilling (depends on filter orientation). Then I disable the ignition and crank the engine over in short spurts (less than 20 seconds with a break in between to preserve the starter) until pressure comes up. Only then do I actually start the engine under load. Overkill? Maybe /forums/images/graemlins/tongue.gif - but I've always heard that most of the wear/damage on most engines is from the "oil starvation" time when you first start it. I figure it can't hurt to ease the pain a bit after an actual oil change.
Can a diesel be "cranked" like that without letting it start? (do you disable the power to the fuel pump or ???) Best I suppose would be to relieve compression (keeping the load off the bearings) by backing off the injectors but isn't that a no-no?
   / Filling new oil fiter before installing #12
<font color="blue"> Can a diesel be "cranked" like that without letting it start? </font>
This is actually a trick I learned off TBN at some point. What I do when I start my tractor is to let it "glow" for about 10 seconds (it doesn't get very cold here - almost never freezes), then crank it with the ignition kill switch in the "off" position for about five seconds. Then I pop the kill switch in and the engine fires right up. This circulates the oil a bit. Don't know how much it helps, but probably doesn't hurt...
43030 (A51691)
43030 (A51691)
Michelin CARGOXBIB High Floatation Tires (SET OF 6) (A53473)
Michelin CARGOXBIB...
stump grinder for mini skid steer (A53421)
stump grinder for...
2022 DRAGON  130BBL VACUUM TRAILER (A53843)
2022 DRAGON...
2004 Fleetwood Wilderness Advantage 365 BSQS 38FT T/A 5th Wheel Travel Trailer (A53424)
2004 Fleetwood...
