Ballast Filling Rear Tires on 1700
   / Filling Rear Tires on 1700
kenmac,
Where did you purchase your adapter? Sounds like after I get enough windshield washer fluid in; that it would be quicker with that adapter instead of a drill pump.
Fig
   / Filling Rear Tires on 1700 #12
In California (and maybe elsewhere), Sears bought a chain of hardware stores OSH:
Orchard Supply & Hardware.
Jim,
We have some orchards around here, but no Orchard Supply Company's.
Fig
   / Filling Rear Tires on 1700 #14
Got mine at Tractor Supply
   / Filling Rear Tires on 1700 #15
Got mine at a local auto parts store near my house. ($11) They also have tractor accessories and parts as well since it is in a rural part of the county where I live. I filled my front tires last weekend on my YM1700. I also finally go my rear tires turned around to the wide side. I wanted to get that done before filling the tires. I plan on filling mine next weekend. This weekend I will be busy with a sailboat race
   / Filling Rear Tires on 1700 #16
The 1700 does great with a couple hundred pounds of weight on front. i made a bumper out 2 sections of big pipe.. fille dem with concrete, and bolted to the front bumper. Made running a 30" dirt scoop doable.. even with a full scoop.
IMHO.. the fronts don't hold enough to account for more than what 20# with loaded ballast max?
Soundguy
   / Filling Rear Tires on 1700 #17
I added 4 50 pd bars of lead and a three foot section of railroad track to the front of my 1500, being as alot of my land is hilly it sure made a differnace.
David
   / Filling Rear Tires on 1700 #18
hey there all... with regard to filling the tires, i was wondering, how do you "unfill'? lets say i do this, but then want to undo? thx. -arthr
   / Filling Rear Tires on 1700 #19
I don't know about tubless tires.On tubes just remove the valve core or stem & the water drains out . maybe same on tubless.
   / Filling Rear Tires on 1700 #20
Ditto.. put stem at bottom of tire.. air tire up a tad.. remove core.. water shoots out. might have to air it a tad more.
Be mindfull of where your ballast dumps.. CACL kills plants... eth glycol AF kills animals...
Soundguy
Deere 331G (A50120)
Deere 331G (A50120)
2010 Ford F550 Service Truck (TITLE) (NOT RUNNING) (A50774)
2010 Ford F550...
2012 JOHN DEERE 10-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A52748)
2012 JOHN DEERE...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A52748)
2016 KBH...
White 6065 Tractor (RIDE AND DRIVE) (A50774)
White 6065 Tractor...
2020 Peterbilt 520 Truck (A51692)
2020 Peterbilt 520...
