art
Super Member
Years ago they had steel wheels for tractors and they didn't have flats either!  The foam will give you everything the steel wheel does except the nostalgic look!  Plus or minus, no tire flex so rougher ride even over the fluid filled tires a minus the plus is no flats.
As posted by GManBart try and get the weight off the front end as it will mean faster wear on steering components, three point is the best using the rear axle with those nice big tires to carry more of the load. Rear axle weights are my second best recommendation as filling the tires hinders traction much the same as foam as it doesn't allow the sidewalls to flex to absorb or deflect when going over bumps.
We found this out with the farm tractors about twenty years ago and have been using it successfully out performing other dealers in demo's with the same make and size! There is so much to balancing and ballasting that if it wasn't for the thousands of tractors we have sold we could have missed it. We still get some that seem to know better till we get them into the neighbors tractor!
