Sprayer Fimco LG-3025 Boomless Sprayer
   / Fimco LG-3025 Boomless Sprayer #11
rswyan,
If the container is Roundup rated, you can alternate it with other chemicals it is also rated for. The better job you do you rinsing it, the longer you can store the Roundup solution (refer to Roundup or generic glyphosate instructions)
To be safe (Roundup is a terrible thing to waste!!!), mix only the amount you need and use it all up in 1 spraying session.
   / Fimco LG-3025 Boomless Sprayer #12
What do you mean by "Round Up Rated?" Are these tanks less porous so that there is less chance for carry over or does the round up react with some plastics?
Eric
   / Fimco LG-3025 Boomless Sprayer #13
blue,
Thanks. Yes, the sprayer is Roundup Ready.
</font><font color="blue" class="small">( Roundup is a terrible thing to waste!!! )</font>
Yeah it is rather pricey isn't it ? /forums/images/graemlins/shocked.gif
   / Fimco LG-3025 Boomless Sprayer #14
</font><font color="blue" class="small">( What do you mean by "Round Up Rated?" Are these tanks less porous so that there is less chance for carry over or does the round up react with some plastics?)</font>
On the Fimco line, Ready for Roundup means that 1) the chemical will not react with the plastic, and 2) that the standard delivery system is calibrated so that Roundup can be administered with no additional adjustments.
In my opinion, it's more a marketing statement than anything else.
   / Fimco LG-3025 Boomless Sprayer #15
Mark,
Sorry this took so long .... took awhile to find the digi cam .... and then I had to charge the battery ... etc, etc.
It's nothing fancy - just threw it and the hose reel on the carryall when I got the sprayer. I did add three swivel casters from Harbor Freight to the bottom when I put the sprayer on .... makes it a little easier to move around.
Ford F-450 Utility Truck (A53473)
Ford F-450 Utility...
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A53473)
2023 NEW HOLLAND...
2024 Big Tex 14GN-40D5A 35ft Gooseneck Flatbed Trailer (A51691)
2024 Big Tex...
UNUSED LANHONOR UHA-16-3000G UTILITY HITCH ADAPTER (A51248)
UNUSED LANHONOR...
2013 Ford Fusion Sedan (A51694)
2013 Ford Fusion...
