Final Drive questions - Not a gear/hydro thing
   / Final Drive questions - Not a gear/hydro thing #11
Another few notes, helical refers to the teeth being angled, not whether a spur or planetary design is used.
A planetary drive needs largish tires to have much ground clearance at the rear of the machine.
Most ag tractors are already too tall to even consider spur setups.
Planetarys are more sensitive to dirt and contaminents in the oil due to their more complicated design.
Either style designed correctly will provide great service. Spurs get a bad name from early crawler tractors (IH's in particular) in which some packaging issues prevented a good design.
   / Final Drive questions - Not a gear/hydro thing #12
I asked the Kubota dealer/mechanic about this. My first Kubota had planatary and the second has spur. The gear and spur are considerably bigger then the planatary set but then, it needs to be. In the end, the mechanic mentioned they never have issues with either drive, both are very long lasting. If a spur type gear did not have long lasting properties, then I suspect most planetary tractors using gear transmissions would also be subject to premature failure since most transmissions also use single point loading designs.
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2019 Ford F150 XL (A57148)
2019 Ford F150 XL...
2019 Caterpillar 289D3 Compact Track Loader Skid Steer (A55973)
2019 Caterpillar...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2020 KUBOTA RTV...
2020 John Deere MX8 8' Rotary Cutter, S/N 1P00MX8HJKP045954, 540 PTO, Hydraulic Rear Wheels, Asset# (A59076)
2020 John Deere...
