Finally built a bridge
   / Finally built a bridge #1
RobA
Platinum Member
Chester County, SE PA
Kubota L5030 HST
I've wanted to build a bridge across my creek for a while now. I thought about a culvert, flat bed trailer, etc but settled on wood both for looks and because wood is easier for me to work with. I also thought about engineering it to hold a truck or tractor but gave up on that since the bridge length wound up being almost 24 feet. I was able to use 3 beams so the longest span was almost 14 feet. It will be used for people, ATV's and horses. The only thing left to do is build up some approach ramps. Thanks to everyone here for their ideas and help.
Some specs:
length: 23'+
width: 8'
max height above grade: 5'
posts: 6 - 6"x6"
beams: 3 - double 2"x10"
joists: 7 - double 2"x8", 12" OC (glued and bolted together)
blocking: 2"x8"
decking: 2"x6"
And some pictures:
Posts set:
Beams up, joists started:
Joists done, adding blocking:
Decking done:
Working on railings:
Done:
Another view:
   / Finally built a bridge #2
Looks good Rob. Very sturdy. What's the plan for ramps?
   / Finally built a bridge #3
Horses ?
Edit; Never mind. Missed the 12" oc joists the first time.
I'd take a CUT across it.
I have an excavator coming this fall to do some other work. I may have him move some dirt to make the approach ramps.
   / Finally built a bridge #7
Yeah Rob, looks really good and the wood theme fits nicely in that creek crossing. Looks pretty sturdy too. I don't think it will fail myself.
   / Finally built a bridge #8
Nice job - sturdy and looks good, too.
The weakest link is where the beams parallel to the creek bolt to the posts. Watch those bolts for rusting over time.
   / Finally built a bridge #9
Great job on the bridge. Thanks for the detailed photos.
Very nice job!
   / Finally built a bridge #10
Nice job.
2007 FREIGHTLINER BUSINESS CLASS M2 DUMP TRUCK (A51406)
2007 FREIGHTLINER...
Ford Pickup Truck Bed (A49461)
Ford Pickup Truck...
2021 John Deere R4038 Self Propelled Sprayer (A50657)
2021 John Deere...
2025 Swict 66in Bucket Skid Steer Attachment (A50322)
2025 Swict 66in...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2017 FREIGHTLINER...
GORMAN RUPP 4 TRANSFER PUMP (A50854)
GORMAN RUPP 4...
