Finally we are building a workshop
   / Finally we are building a workshop #11
Hey Rgillard-
Looks like you are off to a good start on a new workshop. That is very exciting! You are right about steel prices being very high. I used steel poles in my pole barn workshop and they were pretty expensive.
Good luck with your project and have fun!
Mark
   / Finally we are building a workshop #12
Looking great. Weather looks a bit damp.
You can correct the 'wrong picture' by going to 'edit' and deleting that one, if you'd like. /forums/images/graemlins/wink.gif
2 trusses down one to go
between each upright we put lengths of 1" box section between them to screw the sheeting to
once all the sections had been placed between the uprights it was time to lift the trusses. On each end of the trusses we welded 8 inches of 1 1/2" box which would sit into the 2" uprights. This left it very easy then to weld
first truss up.
   / Finally we are building a workshop #17
Great job !!!
I assume all the tubing is 1/8" wall?
Cheers!
once the three trusses were up it was time for a test of strength. The brother decided to do his monkey party piece. it held him no probs which was a relief
lengths of steel were then run lengthwise on the trusses
hadnt got a big enough ladder to put the welder so some improvisation had to be done.im sure a safety officer would have a field day with me
Whiteman 6' Ride On Concrete Trowel (A47384)
Whiteman 6' Ride...
2015 John Deere Z950M 70in Zero Turn Mower (A51691)
2015 John Deere...
Sudenga 10-72 Swing Away Auger (A50514)
Sudenga 10-72...
2002 Wacker RD11A Tandem Smooth Drum Roller (A51691)
2002 Wacker RD11A...
2016 FORD EXPLORER (A51406)
2016 FORD EXPLORER...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A52748)
2-Row Peanut...
